Is it possible to have only the covert art written to the tags and to leave the other parts of the tag alone?
Is it possible to select multiple mp3s and select Discogs tagging, rather than one at a time i.e. some kind of queue system which opens the next mp3 to tag after the prior mp3 tag has been written?
When the Discogs info screen comes up, right-click on the Cover > Extract Cover, it will create a jpg file then hit Cancel so the other tags aren't updated. Then right-click on the Album art area on the tag panel > Add cover and select the jpg file.
You can also go to Tag Sources > Cover Art > Amazon.com and it will only update the album art. That way you can update the tag directly without creating a jpg file.
Yes, the best way is to select an entire album and you can update all the tracks on that album at one time.
regarding 1 can this be done with discogs instead of amazon?
Regarding 2 i am actually tagging art in singles not albums so i am still interested to find another way
Amazing, thank you Dano. I had to change the .src file in both the normal folder and the one under users\roaming etc ... it now does just what I wanted
Do you have a solution to my 2nd question by any chance?
