I just recently updated and the new default actions are a real let down and annoying
What I am finding most annoying is the extract image options no longer go to the folder I am reading the files from but defaults to my documents. Why do this? Di no-one test this feature?
In all previous versions, extract image would open the folder I was reading the files from, and allow me to quickly place or replace folder images. Now I have to navigate to the folder I am reading from each and every time.
No, I am not using a default location for the folders I am reading and writing the meta tags from, hence this becoming a huge PITA.
Can this default behavior be changed back to the way it functioned in every previous build?
