42 character field length instead of 64
I need to reduce the file length to 42 characters in length (incl. extension).
How can I format the Action line?
I think something like this should work:
$mid(%_filename_ext%,1,$sub(42,$add($sub($len(%_filename_ext%),$strrchr(%_filename_ext%,.)),1)))
Another approach:
$left(%_FILENAME%,$sub(42,$sub($len(%_FILENAME_EXT%),$len(%_FILENAME%))))$right(%_FILENAME_EXT%,$sub($len(%_FILENAME_EXT%),$len(%_FILENAME%)))
will give the filename including extension.
will give just the filename.
DD.20061212.1420
Just to freshen up this old thread.
How to shorten the filename to a specific length using Mp3tag Scripting Language?
Goal:
The length of the filename including extension should be 42 characters.
02_YouOughtaKnow~AcousticLive_AlanisMorissette_I_1996.mp3
To:
02_YouOughtaKnow~AcousticLive_AlanisMo.mp3
Solution 1 (will give the filename including extension):
$left(%_filename%,$sub(42,$sub($len(%_filename_ext%),$len(%_filename%))))$right(%_filename_ext%,$sub($len(%_filename_ext%),$len(%_filename%)))
Solution 2:
$mid(%_filename_ext%,1,$sub(42,$add($sub($len(%_filename_ext%),$strrchr(%_filename_ext%,'.')),1)))
Solution 3:
Solution 4 (will give the filename including extension, like Solution 1):
$left(%_filename%,$sub(41,$len(%_extension%)))'.'%_extension%
Solution 5:
DD.20110308.1455.CET
