Hi All,
Not posted on here much but that may change now as i am just trying to tag my entire collection and ripping all my Vinyls to which will also need tagging. I have to say the softyware is amazing and has helped me a hell of a lot.
Anyway... a couple of questions that hopefully i can get some help on....
1 - Is there anyway to set mp3tag going and automatically tag a whole bunch of files in folders if i was to store a text document in the folder with the discogs release id? (i'd have one releases tracks in each folder) or something similar to this. Any suggestions.
2 - Is there a way to use the _Directory rename action in the followning way.
if %band% exists "%band% - %album%" else "%artist% - %album%"
This is due to discogs only outputting a band tag if its a various album so the directory action appears to just pick a random artist from the list in these cases
3 - Is there any info anywhere that i can read that will teach me the code used in this system for expressions and actions etc ... ?
Many thanks
Gavin
