filename filename conversion old pattern $1-$2
new pattern $2
not accepting by mp3tag
2)to get a dash after the first word
REPLACE WITH RE
FIELD>title
RE> (.?)(.)
Rep with> $1-$2
result is i get a dash before the first word>becomes -4shared -93 P Susheela
i tried the following to get a dash after the second word
REPLACE WITH RE
FIELD>title
RE> (.?)(.?)(.*)
Rep with> $1-$2
result is i get a dash >becomes -
tried to delete a few characters from the begining of the string with
.{7} didnot give the result
it shows that the string is being considered as one word by the mp3tag.
how can i get the result?
The converter filename-filename uses
%1-%2
as variables.
You have used the wrong syntax.
Also: Why do you use the filename-converter if you want to modify TITLE?
For the regular expression I would use teh following pattern:
Replace with
$1
You can "throw an anchor", that means, tell the regexp where to start the examination.
For example, the caret sign ^ marks the left side of the given string as the starting point.
$regexp(%_FILENAME%,'^.{7}',)
See also: How to eliminate one character from beginning of title?
