Hello there! I'd like to ask some things about Disc Number and Disc Total columns.
I was wondering if there is a purpose so that fields in Disc Number and Disc Total columns are not able to be clicked like other fields, such as Track or Total Tracks. This means that you can't use a left click on a field in these columns and start typing a value, then confirm it with the enter key. I often edit single files from an album and going through the Extended Tags dialog for each track takes much more time. I only use Track and Disc Number fields for my mp3 files, but I use Track, Total Tracks, Disc Number and Disc Total for my flac files. It would be really convenient if we could edit the fields directly without the need to go to the Extended Tags for each song individually. Here is a screenshot of a clickable Track field: http://i.imgur.com/QOlSBZR.png. It would be great if the fields in Disc Number and Disc Total would be clickable as well
On another note, it looks like the Track Number and Disc Number fields are not sorted the way I was hoping for. I would expect the value 1 to be at the top, following with 1/1, then 1/2, 1/3 and so on. However this is not the case, it seems like the stuff after the forward slash is simply ignored. Here is a screenshot with some of my files sorted by the Disc Number column: http://i.imgur.com/Fu4Nopr.png and here by the Track Number column: http://i.imgur.com/cqowzHK.png.
Thanks for any feedback, much appreciated!
