"Aaliyah, Ginuwine/Ginuwine" Removing Duplicate Artist Name?
I've got a whole bunch of songs where the artist field is formatted like this.
I can't figure out how to remove the /Ginuwine to turn it into this.
Aaliyah, Ginuwine
Can anyone help me?
Some curveballs..
Possible whitespace: 50 Cent, Nate Dogg/Nate Dogg
Action Replace with regular expression
Search pattern:
(if this does not work try: (.*)(\/.*)
Replace with
$1
Try on a single track first to see whether you get the right result.
Action "Guess values"
Source format:
%artist%
Guessing pattern:
%artist%/%dummy%
DD20101212.1439.CET
Thank you! Those seemed to do the trick. :slight_smile:
