Ability to add descriptions to actions
I tend to read and re-read the forums regularly looking for ideas and ways to adjust/speed up my workflow and have come across numerous things that I pull aside thinking to myself that is a great idea and I should save that for future use. I save these under a &Random &#(ACTION DESCRIPTION) grouping....
However here is the issue, sometimes I forget just what it is that these expressions/actions do as I am not overly savvy when it comes to regular expressions. As well, I do not always apply these actions right away. I could always search the forum again for these expressions however they are not always the easiest thing to find after the fact and copying the actual expression into the forum search field doesn't lead to a result.
My suggestion, is there a way to allow a user defined comment/description field to an action outside of the action itself so that you can save things that you might find useful down the road and you can remember just what they do...?
Case in point, I saved something previously which allowed me to pull the First word of a field and one that allows me to pull the Last word of a field now these were easily labelled as what they do but some of the more complex reg expressions can't always be defined in the action name as to their function.
Here is a thread on similar idea (even though it starts off with a different problem):
/t/15634/1
I support this request.
And it is not alone that I could need it for complex regular expressions.
Very often after some time I don't remember what I put in action groups and have to look again inside.
So additionally I would appreciate a tooltip with the content of such a personal description when you hover over the action with the mouse.
Till we hopefully get this feature look here for helpful workarounds:
Add explanations in regexp
