Action : copy filename to %title% or to %work%
#1
In order to use my classical library on Slimserver...
[ http://wiki.erland.homeip.net/index.php/Se...c_to_SlimServer ]
...the %work% tag must be filled.
I managed to swap tags on multiple lines, but not to copy them.
I tried the shortcut filename->tag, but can't make it work.
Same question for the %title% field...
#2
In Convert > filename - tag you enter just %title%
Then the filename is written in the title tag.
#3
Thanks a lot !
Now I must fill %WORK% with infos like %TITLE% or %ALBUM%, according to what is best :
I tried the "converter" : Replace "WORK": %WORK%->%TITLE% but it does not ...works.
#4
To copy tag fields you should create an action:
Actions
E.g.
Action type: Format value
Field: WORK
Formatstring: %TITLE%
#5
Superb! Thanks again.
