Is there a way to import cover art twith a action If a album has cover art but one or more tracks missing cover art?
sorry hopefully last post for a while.
Thanks!
Thanks!
mp3tag does not know anything about albums.
If you have the files organized in such a way that files for one album share one folder, you can first export the pictures with one action and then import them with the next.
The result would be that every file in that folder would get the picture file saved in that folder.
