Does anyone have an action to remove underlies from track titles? I think I would need to use a regex operator but am not familiar enough with regexs to create it myself.
For example:
I want to take a file with the Title field having "No_Place_Like_Home"
and rewrite it so it becomes "No Place Like Home"
If you want to replace one constant character (here: underscore) with another one (here: space), use a simple "Replace" action:
Action of the type "Replace" for TITLE
Search string: _
Replace string:
(insert the space character there - it does not show in the forum output)
