Hi there,
i put this in codec field to get the name MP3 but it dind work, help please:
$replace(%_codec%,'Windows Media Audio','WMA','Free Lossless Audio Codec','FLAC','MPEG 1 Layer III','MP3')
Cover art: how to get more sources?
Hi there,
I think it has to be the other way round:
$replace(%_codec%,'WMA','Windows Media Audio',...
i took this code here, i will look for the link, and try your way, thank you
it did not work also:
Something is wrong here
It was not quite clear where you wanted to have this.
Your original idea was OK, I think:
You can only modify the display in the table but you cannot modify the data for the codec in the file.
The quotes should not be used.
Use this:
$replace(%_codec%,Free Lossless Audio Codec,FLAC,MPEG 1 Layer III,MP3,Windows Media Audio,WMA)
Did not work, for clearing, i want this folder to be:
The Housemartins - Raise The Flag (1997) [256 MP3]
and not
The Housemartins - Raise The Flag (1997) [256 MPEG 1 Layer III]
The Action:
%artist% - %Album% (%year%) '['%_bitrate% %_codec%']'
The value in the codec column:
i have tried this:
the original post was here in the forums but i cannot find it.
Edit: found it: Codec
Edit2: it shows well in the column:
Change the Action to:
%artist% - %Album% (%year%) '['%_bitrate% $replace(%_codec%,Free Lossless Audio Codec,FLAC,MPEG 1 Layer III,MP3,Windows Media Audio,WMA)']'
This work thank you. ![]()
