Action Regex Help: copy features from title to artist with \\ separation
I've gone a bit cross-eyed trying to work out this RegEx. Here is an example of what I'm hoping to do:
TITLE: That's Just How It Is (feat. Ty Dolla $ign, Leon Thomas & The-Dream)
ARTIST: A$AP Rocky
I would like the title to remain unchanged but I would like artist to change to:
ARTIST: A$AP Rocky\\Ty Dolla $ign\\Leon Thomas\\The-Dream
The closest I have come is this:
ACTION: Guess Values
SOURCE FORMAT: $regexp(%artist% - %title%,(.*) - (.*) \(feat. (.*)\),$1\\\\$3)
GUESSING PATTERN: %artist%
which gives:
ARTIST: A$AP Rocky\\Ty Dolla $ign, Leon Thomas & The-Dream
How can I split $3 into the individual items and apply the \\\\ between each?
For further use it should also account for the fact that sometimes there's only a single artist featured ex: (feat. Ty Dolla $ign). If there are exactly two featured artists it is often with an ampersand only and no commas ex: (feat. Ty Dolla $ign & The-Dream). Three or more artists is as the original example, comma separated until the final two which are ampersand separated.
Any help greatly appreciated!
edit tldr:
BEFORE
ARTIST: A$AP Rocky
AFTER
The \\ indicate a multi-value field that you have to merge first to get access to all of the data in 1 string.
Use $meta_sep(artist, & ) or a suitable different separator from the & and then apply "Guess value".
I'm not sure I understand how that would work here. The data is all in one string already (the title), I want to take that and add it to the artist field, thus changing artist to a multi-value field in the process.
I misunderstood, sorry.
You could try:
%artist%\\$replace($regexp(%title%,'(.*) \(feat. (.*)\)',$2),', ',\\, & ,\\)
You would not need "Guess value" but "Format value" would work just as fine as you do not split the contents into different fields.
That is perfect! Thank you so much.
