Action to remove leading zero and total tracks
Has anyone created an action to remove leading zero and remove /total tracks on the track field?
I have been using the autonumber wizard to do this but it would be a lot quicker to just use an action. I have tried to create one but I am failing miserably.
Make a new action
Action type: Format value
Field: TRACK
Formatstring: [$num(%track%,1)]
Thanks for the quick reply, works perfectly :slight_smile:
