Hello all
I've only just started using MP3tag and I'm very enthusiastic.
My files are all APE (APEv2) and MP3 (ID3v2.3)
My folder structure :
E:\Music<artist><year> <track>
MP3tag recognizes all this perfectly.
Some of my filenames are in what MP3tag calls "mixed case"
and I want to convert these to "sentence case" .
I've already done this on TITLE and it works fine
but in FILENAME the is preceded by
(some consisting of one - some of two digits).
How can I ask "Case conversion"
to start the sentence at the first word following the track number ?
Best regards from Ray
RussellRay:
Hello all
Hello all
I'll answer myself.
I did what should have been obvious
and simply added "0123456789"
to the box "word starting after"
probably not the most elegant solution
but it seems to have done the trick.
If there is a cleaner way of representing the track numbers,
I'd still like to hear.
Hello RussellRay!
Welcome to Mp3tag forums in first place!
I've been analyzing your request/method of formatting the filename and i can show you a "cleaner" method to achieve the same purpose:
%1 - Represents the 1st item of the filename (Tracknumber)
%2 - Represents the 2nd item of the filename (Title)
$caps3- It is the scripting function "case conversion Sentence" (I.E.: artist - ALBUM - 01 tItle -> Artist - album - 01 title)
Learn more about these clicking the following links:
/t/7117/1
https://docs.mp3tag.de/scripting
Take care!
