i wondering i have an action called style with two format values strings of hip hop and rock within it. is there a way i can choose these format strings under the style action when i need them or do i have to use separate actions. i'm trying set theses type of strings under one action. Thanks Dp
So would i place the submenus inside the style action and the fromat strings inside the submenus. i'm a little confuse on setting up the submenus. i did read the doc that you sent, just don't undstand it.
How have you selected functions from a submenu until now? @dp19: you know the game meanwhile:
You get a suggestion and then you tell as thorough as possible what you do with that suggestion.
I cannot look over your shoulder from the distance. And as I don't see it, you have to describe it.
Besides the link to the documentation you also got an example. I do not feel like telling it again.
So, please tell me where you think a name of an action is applicable and what result you got.
What do you mean by "under style action" - and how does that correspond to the
(groups - as an action group is the only item that you can give an individual NAME)
I am pretty sure that you have created named actions before like e.g. here:
ok here's a screeshot. i've created a action call style and put the submenus inside that like i read from the post. is this not correct? if so how to i set them up please?
As we all try to improve the support: where did you have the problems?
Which are the passages in the documentation that should be modified? And what should they look like?
