Actions Help - Change , to &
I was wondering if it were possible to change , to & using actions only under certain conditions.
For example, often times artists comeup as
bob, dan, sue
or
bob, dan
I want to create an action so that the following scenarios will change to
bob, dan & sue
or
bob & dan
Is this possible? Thanks!
Trty an action of the type "Replace with regular expression" for ARTIST
Search string: (.*), (.*)
Replace string: $1 & $2
The greadiness will take care that always the last comma gets replaced.
