Actions in 2.2.1 b and c
Hi there,
when I try to use the actions in 2.2.1 b/c it takes forever and doesn't work. The programme can't be closed by the menu file => end, but by the x! When i try to start it again it reports an exception error.
I thought the problem lies within my machine, but I've encountered no problems with 2.2.1. release.
Any ideas?
Flo
Can you please sent me all your *.mta files for testing purposes?
Thanks!
~ Florian
No need for the action files anymore - the bug should be fixed in the latest Development Build.
Thanks for reporting!
~ Florian
Great. It works again!
Flo
BTW: You got a typo in your Development Build Posting
