Hi All.
I Would like to remove "www." from mp3 filenames.
Exemple:
Artist - Title [www.somesite.com].mp3
I'd like to get:
Artist - Title.mp3
Is that possible to get this result using regular expressions, and how?
Hi All.
Exemple:
I'd like to get:
Artist - Title.mp3
You do not need the obvious power of Regular Expression, simply use the dialog "Mp3tag/Convert/Filename - Filename" to solve your problem (hmm ... there might be working a Regular Expression behind the scene).
Convert | Filename - Filename | ALT+3
Select format string
Old filename pattern:
%1 - %2 [%3]
New filename pattern:
%1 - %2
Preview
Artist - Title.mp3
DD.20100903.1604.CEST
Ok. that could be solution, but i have already configured few expressions in Convert --> Actions. I'd like to have a "one click" tool to tidy up my mp3's. That's why i suggested expressions (as a wish).
You may set up the tags properly (what is recommended), ...
Action: Guess values
Source format: %_FILENAME%
Guessing pattern: %ARTIST% - %TITLE% [www.%DUMMY%]
... then you can use ...
Action: Format value
Field: _FILENAME
Formatstring: %ARTIST% - %TITLE%
If you like it complicated in one step ...
Field: _FILENAME
Formatstring: $regexp(%_FILENAME%,'^(.+?\s-\s.+?)\s(?i)[www..+?]$','$1')
DD.20100903.2141.CEST, DD.20150721.1518.CEST
