"Actions" variable questions
Is there a variable in Actions that can return the numerical place of a given song in a list of songs?
Also, how can I prepend the %track% variable with a number and a dash (like "02-") in an Action (to indicate, for example, the disc number in a multi-disc set)?
Thank you.
there is the variable %_counter% that counts each file in a set of selected files.
see the FAQs: Actions and batch-operations - #5 by dano
Yet, I would not do that as the field TRACK is defined as being numeric with the exception of the / to separate the total number.
