Request for a new group of actions that are able to send alt & ctrl charaters to mp3tag.
For example, ctrl A to select all files or ctrl D to change the directory.
So I can code
ctrl D - change directory, now I have to click on a directory from the popup window
ctrl A - to selects all the files
alt 2 - to copy the filename pattern to the tags
alt 5 - to start again from ctrl D
Yes I know, I'm a lazy $%^***$% ![]()
But, amongst the rubbish that is on the web - this is one of the rare great programs
Keep up the good work
Thanks
Pegleg
