I hope I can make this understandable.
I'm trying to list and number various versions or takes of songs in alphabetical order i.e. Song take 1, Song take 2, etc.
Arranging using the title button at the top of the column is fine until you have versions or takes which are in double figures and then versions 10,11,12, etc are sorted between versions 1 and 2.
Using 'Actions' how can I add a 0 (zero) in front of any single digit number found in a particular field, in this case, TITLE ?
Thanks in advance for any help.
