Patu
1
Sorry, I'm a newbie to this.
I've been trying to add a dot at the end of one or more numbers by searching for \d and replacing it with \d. But that doesn't work at all.
There are three problems:
- I don't know whether to use action type "replace" or "replace with regular expression".
- I don't know how to replace a number with itself + a dot (e.g. "1" = "1.").
- The dot should only appear at the very end of a string of numbers ("123" = "123.").
Any idea?
use reg exp on TITLE tag for instance: (\d+)
replace with: $1.
The () capture whatever regexp is placed inside and the + captures the digits until it can't find any more.
The $1 with the . Replaces the captured regexp with a . At the end.
Hope this helps.
Patu
3
Great, Steve. That was very helpful.
It's just amazing to watch mp3tag change Hundreds of files in a wink.
Thank you. Thank you. Thank you.
No problem. If your interested in learning regexp.
A great resource is www.regular-expressions.info/
I also bought a program called regexbuddy which is around $30 but definatly increases your learning curve a lot.
Glad to help and welcome to the forum.
