Can you please add option to play files direct from mp3tag?
This will help identify musics when tagging.
Thanks
Thanks
It's not planned at the moment, you'd need another app side-by-side to play the files.
You can play files if you double-click on files in the list-view or use right-mouse-click-Play.
The music will be played by your standard player for the file-format.
