Add another genre
#1
Is there a simple way to add another genre to a group of files regardless of the current genre. The outcome being that the files end up with 2 or more genre tags.
I'm mainly dealing with flac files.
Thanks
Richard
#2
Try "View > Extended Tags" or in the tag panel write genre old\genre new
#3
I can do that manually if I group files where "genre old" is the same for all files. I'd like to be able to do in one hit for a group of files where the original genre or "genre old" is different.
Thanks
Richard
#4
True, also Extended Tags doesn't work at all.
DetlevD had a nice idea:
Add a custom tag field (i.e. ADDGENRE) to your tag panel at "Options > Tag panel"
Then create an action group format value
Field: GENRE
Format string: $meta_sep(genre,\)\%addgenre%
Enter your new genre in the addgenre field in the tag panel, then call the action.
#5
That did exactly what I was trying to do.
Thanks for your help.
Richard
