Add parentheses To featured artist
I want to add featured artist
For example
artist
Michael Jackson Feat. Akon
to
Michael Jackson (Feat. Akon)
I have been trying this for a while and it is probably simple but is driving me crazy
Would have been interesting to see what you have been trying....
Create an Action Group that consists of two actions:
a) A replace action (just normal replace) that, in the field artist, replaces "Feat." with "(Feat."
b) a replace with regular expression action that, in the field artist, replaces $ (which stands for "end of string) with a ")"
You should apply a suitable filter first as this action simply adds the characters and does not check whether they are already there. If you run the action group twice, you will get duplicate brackets...
Action: "Format value"
Field: ARTIST
Formatstring: $replace(%ARTIST%,' Feat. ',' (Feat. ')')'
DD.20100824.1210.CEST
To avoid side effects ... set ...
Filterstring: ARTIST HAS " Feat. "
Edit. DD.20120705.1911.CEST
Is it possible to do this but put the (feat. artist) before another group of parentheses, for example:
Artist: Armin van Buuren feat. Laura V
Title: Drowning (Avicii Remix)
to
Title: Drowning (feat. Laura V) (Avicii Remix)
Action: Guess values
Source format: $regexp(%title%,(.) ('('.')'),$1) ($regexp(%artist%,(.) (feat.),$2')') $regexp(%title%,(.) ('('.')'),$2)===$regexp(%artist%,(.) (feat.),$1)
Guessing pattern: %title%===%artist%
Awesome, works great if there is parentheses in the track tag but if there isn't the track results in the following (using a similar example):
Title: Drowning
to
Title: Drowning (feat. Laura V) Drowning
use this Source Format:
$regexp(%title%,(.) ('('.')'),$1) ($regexp(%artist%,(.) (feat.),$2')')$if($eql($right(%title%,1),')'), $regexp(%title%,(.) ('('.')'),$2),)===$regexp(%artist%,(.) (feat.),$1)
works for both, title with or without version names in parenthesis.
Thanks
This works great on tracks where the Artist tag does contain a feat. artist.
If the action is done on a batch of tracks, those which do not contain feat. artists the artist is copied into the title tag like so:
Title: Drowning
to
Title: Drowning (Armin van Buuren
And also
to
Title: Drowning (Armin van Buuren (Avicii Remix)
Is there anyway to fix this or can this action only work correctly on those files which have a feat. artist in the artist tag?
That was what you asked for. Please be more exact what different cases the action should cover.
You can use the filter (F3) with %artist% MATCHES " feat" to display only those files which have a " feat."
But anyway, i like regular expressions, here is your Source Format for artists with or without feat and titles with our without versions in parenthesis:
$regexp(%title%,(.) ('('.')'),$1)$if($eql($regexp(%artist%,.* (feat).,XXX),XXX),$regexp(%artist%,(.) (feat.), '('$2')'),)$if($eql($right(%title%,1),')'), $regexp(%title%,(.) ('('.')'),$2),)===$regexp(%artist%,(.) (feat.*),$1)
different writings of the feat. like featuring, ft., Feat. would be the next problem, right?
Thank you for your help, sorry I wasn't more specific as I assumed it would just work like that.
Nope, I already have an action for that. :rolleyes: Thanks.
pone can u please help me with my only problem ??
I Have the tags like this:
artist: Akon
Title: Give It To Em feat. Rick Ross
i want to make like this:
artist: Akon & Rick Ross
title: Give It To Em
i already have an action to replace (feat. - featuring. - ft.) to (&)
thank u in advance
Haven't you posted the same question here?
how to move (feat.) from title to artist - HELP
yes.
sorry but didn't work
so I see dano has already fixed Ohrenkino's string in the other post.
no double posts please.
thank u and sorry for double posting.
