I actually use two softwares to renam music files that I download :
- Ant Renamer to clean the filename
- Mp3 tag to reset all tags and to convert name file to several tags.
I think it would be better to use ony one software. Indeed, mp3tag just need to add this functionnality to any column (file name as ant renamer, but ALSO tags...) :
- string replacement : replace string by another
- string insertion : insert string at specified position
- Change case : all upper or all lower or upper only the first letter of each word or upper only the first letter after any of specified character.
What do you think about this idea ?
mp3 tag is great, many thanks !
