Hi, I was looking for something like the subject of this thread, how to make the icons bigger and customize the buttons on the toolbar, because it's annoying to have to select with the little arrow between the different Discogs search options, wether I need artist+title or ID or whatever but it's surprisingly sad to see that after all these years this feature is still not available.....
If you want to avoid the little arrow, rename the files of the web source scripts and remove the # from the filename.
Yes.
Covert Art#Discogs Artist + Album.src
would become
Covert Art Discogs Artist + Album.src.
I have to admit that I found the grouping for the cover-art-only scripts under "Cover Art" quite intriguing.
Thanks for your answer, but sadly, it didn't work, still the same...
Have a look:
Still need to click on the small arrow to select between the several options.
Oh that one.
Yes - that one does not go away.
The button next to it in the left, though, recalls the last used web source script.
So if you structure your workflow that you group all the titles that get information from the same wss, then you only need to click that button for each file.
You have to use the button-with-the-arrow if you want to change the wss.
