I have 6 albums, they have different amount of MP3 files.
I load all these albums into Mp3Tag
If I select all files
And I use Format Value:
TOTALTRACKS
to
%_total_files%
It would set total tracks to songs of all 6 albums
So I can't use this method /t/12205/1
Because it only works with selected files.
There has to be a way to do this automatically without selecting albums one by one and applying these tags.
Maybe using Guess Values and using values %track% and %_directory% (for differentiating between folders)
May I use request a new varible %_total_files_directory%
TOTALTRACKS
to
%_total_files%
Yes, but the answer is the track numbering wizard and no action.
You can't reset a counter in actions.
