my eac rips the tracks as 01 - trackname.flac
I want to use mp3tag to auto tag a selected group of files as 01 - a trackname.flac
how can I set this up to do it automatically, using the alphabet a,b,c
example:
01 - a trackname
02 - b trackname
03 - c trackname
and to include the space between the a(letter) and trackname
These formulas work for the range 'A'..'Z', for TRACK=1..26
$char($add(64,%TRACK%))
... or ...
$char($add(64,%_counter%))
... or ...
$mid('ABCDEFGHIJKLMNOPQRSTUVWXYZ',%TRACK%)
These formulas work for the range 'a'..'z', for TRACK=1..26
$char($add(96,%TRACK%))
... or ...
$char($add(96,%_counter%))
... or ...
$mid('abcdefghijklmnopqrstuvwxyz',%TRACK%)
You may apply the Mp3tag Convert dialog "Filename - Filename" ...
Old filename Pattern: %1 - %2
New filename pattern: %1 - $mid('abcdefghijklmnopqrstuvwxyz',%1) %2
Please explain for which practical use it is worth?
For some strange reason my car stereo does not use number tag when playing the audio track, instead the player will sort by alphabet a - z and rearranges the files as such.
