Is it possible to add an ARRANGER tag, for example for a piece that's by Manuel Ponce, with Jascha Heifetz as the arranger?
Many thanks!
Many thanks!
You can add more or less any field name to the tag in ID3V2.3ff.
Here is a list of standard fields as defined in the ID standard: http://id3.org/id3v2.3.0
Here is a list of fields supported by MP3tag.
I would think that the "arranged by" would be a good token for the field "involved people" (Tag Field Mappings – Mp3tag Documentation)
"Arranger" BTW is then no standard field and will most likely be not recognized by any player.
