Adding Coverarts to same-name-mp3file
I have - let's say - a folder with a hundred of files following the format:
Song One.mp3
Next Song.mp3
So every jpg file covers a mp3 file of the same name.
Is it possible to add those jpg file to the according mp3 files without doing it file by file?
see here:
Hm, looks like it is the solution, but...
where do I enter that %_filename%.jpg? I do not find the according menu :frowning:
You have to use an action.
See the FAQs on how to use/create actions:
Also see there an action to import covers:
Waoh, perfect - thank you a lot, worked like a charm!
