Adding some text to a trackname?
Can someone please help me to change the TRACKNAME so that I can have (DJ BEATS) displayed before the track name on every track within a folder?
I just can’t figure out how to do it?
What could that be?
The filename?
The metadata tag field TITLE?
You could use the function Convert>Tag-Tag for the target field.
Select as field the target field.
Enter as
Format string: (DJ BEATS) %target field%
Thank you so much for the quick reply, I’ll try this now :wink:
Thanks once again, it’s worked perfectly, exactly how I had hoped :wink:
