Adding Text To Title (Sorted)
Have used search but nothing is coming back to what I want to do.
Have a load of audio book (MP3) files that are named 1 of 400 up to 400 of 400, how do I rename them to include title of book in the title - Dune 1 of 400, Dune - 2 of 400 etc keeping the numbering...
Regards
Jay
Maybe this helps you /t/967/1
Thank you for the reply...
I did look at that before I posted and it does add text but I want to keep part of the original title, I want to change the title from "1 of 400" to "Dune - 1 of 400" and would like to to do for all the 400 files in one go, using the above strips everything and adds your %comment%xxxx unless I'm not doing it correctly...
Jay
Well it is just an example and you must adapt that to your own situation.
So try this format string:
Dune - %title%
Cheers, that's the one, I was using %comment% all the time while trying various things..
Regards
Jay
