I've recently moved all my mp3s to the iTunes library.
The thing is that by doing so, the field FILENAME is automatically changed from:
01. Song
to
01 01. Song
This may be due to the fact that for browsing reasons, I had found it so far easier to insert the song number before the TITLE within the FILENAME field.
Could I, by any chance, change all the filenames in my iTunes Library so that to keep the 01. song format (I'd like to keep the . if possible, but if iTunes just removes it, that's fine).
Thank you for your help that has been so far great.
Just curious why do you not take advantage of the function of organising music files in iTunes. It ensures all the songs are in the correct place in relation to their tags. If you change an album name for example once you play the file it shifts it to the corresponding new named folder (which might save some confusion later on). Also why not search your music from iTunes? Its much much faster plus your not limited to just the song title.
Your files you mean? You tag the files in mp3tag. Drag them into iTunes. And same tags appear there. If you make any more changes to the file in mp3tag then you have to play the file in iTunes for them to update.
What do you mean 'reorganizes my tags without asking'? Personally I don't care what what the files look as long as iTunes reads the tags properly. iTunes is way more powerful internally by means of smart playlists and organising music than windows explorer will ever be.
If your worried about iTunes leaving behind empty folders see /t/13629/1
As I said earlier (and it is a well-known problem for iTunes users as seen on countless forums), iTunes automatically changes the FILENAME field as soon as you drag your files into iTunes.
Namely, it adds the TRACKNUMBER field and sticks it in front of FILENAME (leaves a space in-between though). Hence, it does change my tags without asking.
As for the " Personally I don't care what what the files look as long as iTunes reads the tags properly", well...good for you!
Are you sure that it does this when you have the "automatically organize files" UNCHECKED in itunes? Itunes hasn't changed the filenames on my mp3 files at all with this unchecked, and I have over 50,000 files in itunes database.
