Hi all, i want to assign odd track numbers to certain mp3 files and even track numbers to certain other files. I didn't find any such option in mpetag. I'm using v2.69. Any ideas?
1. Select the files to be numbered.
2. Action "Format value"
... or ...
Convert "Tag -Tag"
Field : TRACK
Formatstring for odd numbers : $sub($mul(2,%_counter%),1)
Formatstring for even numbers: $mul(2,%_counter%)
Begin Action Group Format &TRACK#Set TRACK count 1,3,5,... odd
Action #1
Actiontype 5: Format value
Field ______: TRACK
Formatstring: $sub($mul(2,%_counter%),1)
End Action Group Format &TRACK#Set TRACK count 1,3,5,... odd (1 Action)
Action #1
Field ______: TRACK
Formatstring: $mul(2,%_counter%)
End Action Group Format &TRACK#Set TRACK count 2,4,6,... even (1 Action)
DD.20150331.0827.CEST
There is a self-extracting archive file, ...
which contains 23 TRACK related actions ...
20150331.Mp3tag.Actions.TRACK.zip (122 KB)
DD.20150331.2002.CEST
Wow! thanks DetlevD. You solved my problem. I didn't understand what that code meant. but it worked. thanks for your time. Thankyou very much.
