Adjust album art doesn't work if many files are selected
When making my music album art smaller selected all (about 1500 files) and then going to Edit > Cover > Adjust cover and entering 800 in the max size box. The prompt will immediately close and clicking save shows it writing tags, but the image sizes don't change when done.
It does work when selecting a few (about 15) as it should.
I'm using v3.20
Just tried it with 60 files which had the sizes
500x446
500x442
600x536
and used the function to adjust covers to 300
which led to
300x267
300x265
300x268
I would say it works ...
Not sure why but it working now. Only thing I change was turning off the correct aspect ratio option.
And? Have you (repeatedly) tried the 2 variations if you suspect that this is the cause?
