Adjust cover: Quality not working as a single change
I was hoping to use the Adjust cover... ➜ Quality feature to lower the file size of artwork without having to put it through a batch process in an image editor to do so.
Currently, Mp3tag only creates a new adjusted image if a lower resolution or different file type is applied which doesn't seem right.
