See this when the horizontal scroll is on the left hand side. Looks okay.
When the scroll is on the RHS. The edit box isn't aligned.
Thank you for reporting the issue.
Can you describe how you scroll? If I scroll via the scroll bar, the editing mode is ended.
I first scroll and then edit.
Because if you edit and then scroll the edit box becomes inactive.
Thanks for the clarification. This is now fixed in Mp3tag v3.21b.
