Hello,
I've used the "Adjust tag information" Windows after searching tags from the web and i think it would
be really usefull to synchronise the two grids in this window.
In that case, when we use the side bar to move in one grid then the two grids would scroll at the
same time.
Like this, the corresponding lines of the two grids would always be on the same level. It would be very
usefull to check the before/after changes.
Would it be possible for the corresponding lines of the two grids to be highlined at the same time ?
Excuse me for my English, i hope i'm sufficiently understandable.
Thank you for reading this.
