Adjusting embedded artwork size deletes lyrics
Hello folks,
since i bought myself a DAP i need to resize the embedded artworks on my FLAC collection.
The current artwork size is 1280x1280, but my DAP only supports 600x600. I tried to use MP3TAG to accomplish the task and did it nearly flawlessly. My DAP instantly could load the artworks perfectly. But all my embedded lyrics are gone! So i got two questions... First, why is MP3TAG deleting my embedded lyrics if i change the artwork size, and Second, how do i stop MP3TAG from doing this?
Thanks in advance,
gramo
TBH I could not reproduce such a behaviour.
I took a flac file with lyrics in UNSYNCEDLYRICS and an embedded picture of 350*350 pixels.
I right-clicked on the tag panel section and selected `Adjust cover ..." and set the size to 300, clicked OK and finally Ctrl-S to save the modification and the lyrics stayed.
hmm.. i am kind of a lazy guy.. so for example i put all my flac files from artist x (around 200 files) into MP3TAG. Every flac has LYRICS or atleast UNSYNCEDLYRICS. After adjusting all the artworks at once, the embedded UNSYNCEDLYRICS stay, but all the embedded LYRICS will be deleted. No matter what what i do. Even if i try it file per file...
Does LYRICS get deleted if you modify other data?
Or: could it be that you have a mapping that maps LYRICS to UNSYNCEDLYRICS?
