MP3tag has become my software of choice for managing my digitized CD collection. I have ripped my CD's into a directory structure Genre->Artist->CD Title->tracks.mp3 With each track having the information in the tags filled in.
I would like to be able to do somewhat complex searches (like all tracks by Artist X between the years xxxx and yyyy where the Composer is Z and Lyricist is A or B). This could be done through boolean searches and using drop-down boxes. Then I can create a playlist if such a filtered list is there in the right pane ...
Maybe some such filter option already exists. How can I create such searches and filters?
I also have a PalmOne Treo 650 which I use to play MP3's. The SD card in the Treo can be accessed using a card reader (mapped to a drive in Win XP). It would be nice if MP3tag would have a way to copy the MP3 files (and the corresponding playlist) to a desitnation directory.
Then I can combine my search functions to generate .m3u files and listen to my tracks on the PC or copy the mp3 files and the m3u file to the mobile handheld device.
You can also copy the files with drag&drop (right click) or with the masstagger plugin.
Playlist tree also has an option to specify a path where you can send files to from the context menu.
In case Florian wants to add features, in addition to advanced filters, an option create a random selection (of total of xx megabytes) will also be nice. Then, with the help of drag-n-drop, I'll be able to load up my handhelds with random songs.
It will be like having an iPOD Shuffle without actually having one.
