It's bugged me for a while I think I should report this.
I'm not good at explaning so I'll just quote, what is Aero Snap:
"To make it work, just click the title bar of a window and drag the window a-a-all the way to the left side of the screen. Windows 7 docks the window to the left side of the screen and shrinks it to half size. "
I know this feature works in ALL windows except Mp3tag.
In mp3tag, Aero Snap only works when I use the keyboard shortcuts.
Hello again, I've found the problem and the solution.
Aero Snap for Mp3tag is not working when "Show window contents while dragging" is not enabled.
How to enable that:
Go to My Computer and right click Properties
Click Advanced system settings
Click Settings under Performance
(Visual Effects) Check the box named "Show window contents while dragging"
The reason I did not figure this out earlier because I uncheck/disable all Visual Effects.
Please fix this bug. Now that I've found the problem... please...
