Revolut
Here's something I wrote to automatically run a script outside of Mp3tag, in my case foobar2000.
Any CLI will work so long as AHK is supported.
It'll ask the user to close once the saved file operation is finished. So all you'd have to do is go through the List of search results window and then ensure the adjust tag info is ok. Then a yes, no dialog where all you need to do is press enter to close Mp3tag.
So 3 baby steps ![]()
You need to change some stuff for this to suit your needs so read the header of the file carefully.
Just the CLI command needs changing in the latest release
If you've any questions just ask. Or if you have any improvements too, then please let me know.
Icon for anyone who may need it ![]()
Script in action
Code to save to the .ahk file
; # Tag with Web Source Scripts in Mp3tag.ahk written by stevehero
; # Version 0.1 beta - 2021.02.16 - First release.
; # Version 0.1a beta - 2021.02.17 - Improvements and bug fixes.
; # Version 0.1b beta - 2021.02.18 - Improvements.
; # Version 0.2a beta - 2021.02.23 - Rewrote entire thing to use functions and timers for the various window
; # changes. This helps increase the speed of the script as there's no hard
; # coded Wait commands in there. Also leaves it easier to edit.
; # - CTRL+ESC key will close Mp3tag at any time throughout.
; # - Splash screen and MsgBox are centered to the Mp3tag window.
; # Version 0.2b beta - 2022.01.22 - Tried to fix the problem with the script sticking (sometimes) after opening
; # in Mp3tag. Works better but not foolproof.
; # Version 0.2c beta - 2024.03.09 - Correct fix for the problem with the script sticking after opening and not
; # loading any files in Mp3tag and running the script.
; # You can buy me a beer or an EP on beatport
; # https://revolut.me/stephen147
; # WHAT IT DOES WITH FOOBAR2000 OR ANY CLI:
; # when you use this it will fire the appropriate keyboard shortcut to use the
; # correct script.
; # As an example in Mp3tag to search by album artist and release the keyboard
; # shortcut is: Alt, S, S, R. so this will run that depending on the arguments
; # you give it.
; # See the section below 'SYNTAX'.
; # HOW TO SET-UP SETTING WITH FOO_RUN:
; # 1. First, download and install the plugin and AHK.
; # https://www.foobar2000.org/components/view/foo_run
; # https://www.autohotkey.com/
; # 2. Save all of this code to a file: Tag with Web Source Scripts in Mp3tag.ahk
; # 2. Go to: File>Preferences>Tools>Run Services.
; # 3. Click on Add.
; # 4. Give it a label such as:
; # Tag with Beatport - Album Artist - Album
; # 5. In the Path field use:
; # HOW TO USE:
; # 1. Select a single track or the full album you want to tag in foobar2000. The
; # way this works is it loads the directory of the track selected. Typically
; # an album has its own directory anyway.
; # 2. Run it via the right-click context menu or alternatively you can add it to
; # a toolbar.
; # 3. This will then run the script depending on the keyboard shortcuts used.
; # NOTE:
; # If you modify this make sure there's a keyboard shortcut to the script in
; # Mp3tag first otherwise it won't work.
; # SYNTAX:
; # Wrap any paths with " (Quotes).
; # "<AutoHotkey Path.exe>" "<Path to AHK Script>" "<Path of folder to process in Mp3tag>" "<Short cut keys>"
; # Here's my working example:
; # "W:\Apps '('Portable')'\AutoHotkey\AutoHotkeyU64.exe" "W:\Apps '('Portable')'\Music Apps\foobar2000\.autohotkey-routines\Tag with Web Source Scripts in Mp3tag.ahk" "%_path%" "{s}{s}{r}"
; # MP3TAG THREAD:
; # https://community.mp3tag.de/t/ahk-to-auto-run-a-web-source-script-from-outside-mp3tag/52002
#SingleInstance,Force
SetTitleMatchMode,RegEx
#Persistent
arg = %1%
global keystopress
keystopress = %2%
global msgBoxTitle
; Open Mp3tag first
if WinExist("Mp3tag v.*") {
WinActivate
Run, "W:\Apps (Portable)\Music Apps\Mp3tag\Mp3tag.exe" "/fp:%arg%",,xPID
else
WinWaitActive ahk_exe Mp3tag.exe
; Set up the timers after first trying to open Mp3tag
SetTimer, CenterMsgBox, 10
SetTimer, CenterSplashScreen, 10
SetTimer, Close, 1500
SetTimer, IsReady, 1500
SetTimer, IsSaved, 500
SplashTextOff
^Esc::WinKill ahk_exe Mp3tag.exe
RunKeyboardShortcuts() {
; Select all the files and SendInput the Alt key to access the menu and run the web source script.
Sleep, 500 ; Wait a small amount of time first.
SendInput ^a
SendInput {ALT}
; Here are the keyboard shortcuts for the Mp3tag script. Change the CLI in your program to suit.
SendInput %keystopress%
; Automatically accept the search box.
SendInput {ENTER}
return
AskToCloseMp3tag() {
msgBoxOptions := 4
msgBoxOptions += 32
msgBoxOptions += 4096
msgBoxTitle = Close Mp3tag?
msgBoxText = Do you want to close Mp3tag? (Press YES or NO)`n`nIMPORTANT`:`nYou will not be able to undo previous changes made.
MsgBox, % msgBoxOptions, %msgBoxTitle% , %msgBoxText%
IfMsgBox, Yes
WinActivate
Exit
IfMsgBox, No
Exit
Return
CenterSplashScreen:
IfWinExist, Please Wait`, Loading Files from...
WinGetPos, , , msg_W, msg_H, Please Wait`, Loading Files from...
SetTimer, CenterSplashScreen, Off
WinMove, Please Wait`, Loading Files from..., , (mainUIW/2+mainUIX-(msg_W/2)), (80+mainUIH/2+mainUIY-(msg_H/2))
return
CenterMsgBox:
IfWinExist, Close Mp3tag?
WinGetPos, , , msg_W, msg_H, Close Mp3tag?
SetTimer, CenterMsgBox, Off
WinMove, Close Mp3tag?, , (mainUIW/2+mainUIX-(msg_W/2)), (mainUIH/2+mainUIY-(msg_H/2))
return
IsReady:
StatusBarGetText, RetrievedText, 1, ahk_exe Mp3tag.exe
If (RegExMatch(RetrievedText, ".*Ready.*")) {
; MsgBox, %RetrievedText% is found.
SetTimer, IsReady, Off
Return
; Here's where the script will check if the files have been saved and give the user the option to close the Mp3tag.
; The default button here is Yes, so you can just hit enter.
IsSaved:
If (RegExMatch(RetrievedText, ".*Saved tag.*")) {
SetTimer, IsSaved, Off
Sleep 50 ; Give it a little more time.
AskToCloseMp3tag()
Return
; Close the ahk script when Mp3tag is closed.
Close:
IfWinNotExist ahk_exe Mp3tag.exe
ExitApp
; Exit
Return
;; End code
