Hello, is it possible (if not can you make it possible?) to display the album art in the tag panel to the left side of the editable fields (Title, Artist, etc)? (In my case the tag panel is positioned at the bottom of the screen, so having the album art to the left instead of below the tag fields would allow me more screen dedicated for displaying the various mp3 files in my music folder)
Hello, hope you are doing well. I also have a question... is it possible to remove Album Art Display from the panel altogether?
thx
Do you mean that:
EXTRAS
Optionen
Tag-Panel
on the right side, uncheck "Album-Cover anzeigen" or something like that in english...
File>Options>Tag Panel>Uncheck Display Album Art
thx
bump for 1st post request
