Hi all,
How do I add "Album Artist" and "Track Artist" tags? I need them for albums containing various artists.
Also, what is the difference between these tags and the "Artist" tag?
Thanks
Hi all,
Thanks
The standard Artist field you see in the Tag Panel is the normal Track Artist. If you want to edit the Album Artist, just add a field BAND at Options > Tag Panel or add a new column to the file list using this field.
You can also edit this field via the
Extended Tag Dialog.
cool, thanks
