I try to check for this topic before posting but I could not find anything matching it. Maybe you could help.
Is there any possibility to add the string "Various Artists" in the field "Album Artist", to select it on the scroll down menu, without having to type it all times?
in the main screen interface of mp3tag, among the fields on the left side, there is the field "album artist" and scolling down the possible available strings there is only and
I was trying to include as optional string because of the multitude of compilation existing. I could not find in the settings any possible option to add the above string and I was wondering if someone else already requested this add-on to the developers. Only to avoid having to type all times "Various Artists" on that empty field.
There is no option to define default values for such a field.
But there are some other ways to handle it:
The tag panel and its entries work for all the files that you have selected.
So: select all the files that should get "Various Artists" as data for ALBUMARTIST.
Enter "Various Artists" in ALBUMARTIST.
Press Ctrl-S to save the modification.
All selected files will get the new data - and you have typed it only once.
Or you add a master file that already has the correct data in that field.
Select the master file and all the others that should get the data.
Select the required data from the dropdown list.
Save the modification.
Or you could create an action of the type "Format value" for ALBUMARTIST that sets the desired string into that field...
Once you have selected more than one file in the Mp3tag Listview, ...
and at least one of these files already has set a tag-field ALBUMARTIST ...
containing the value 'Various Artists', ...
then the edit field for "Album Artists" in the Mp3tag Tag-Panel ...
offers the value 'Various Artists' in the edit field's drop-down list.
There is no way to preset user defined values into the Tag-Panel edit fields ...
for the tag-field ALBUMARTIST.
If you need the value "Various Artists" rather often, ...
then create an action of type "Format value" to set the tag-field ALBUMARTIST to "Various Artists".
If you want to work on the tag-field ARTIST and on multiple files, ...
then you can define a standard value in the dialog "Mp3tag Options/Tag Panel/Default values".
MP3tag is so good because it does not favour one particular workflow but offers many options to configure a local system.
The suggestion is now public - but I doubt that it will ever become a program feature as there are so many ways to adapt MP3tag to your needs that you don't need anything ready-made.
But who knows. In the meantime, you can use one of the alternatives.
