Album Column Won't Sort
Have V2.95 and the Album column doesn't sort. The arrow changes to up/down but nothing shows different in the column.
Could you check the column definition whether numeric sorting is activated?
If this is so: switch it off, so that it sorts alphabetical again.
You find the column definition if you right-click on the column header and then on Columns ...
The numeric sorting wasn't checked but the sort field had %filetype% in it. I changed it %album% and seems to be working now.
if you sort by the field contents anyway, it is not necessary to use special sort criteria. You may leave the sort field empty.
Thanks. That worked too.
