Hello,
In my mp3 library, some files do not display the album cover on my car radio. After examination, these covers are in webp format and not jpeg. How can I "easily" locate these covers in my playlist so that I can change them?
load all files into MP3tag.
Enter as filter:
%_cover_mimetype% HAS webp
Select the filtered files
In the tag panel right click on the cover-square and select
"Adjust cover".
There select jpg as cover format.
Press Ctrl-S to save the modification.
Great! It works really well! Thanks a lot!
