Album with catalog # pattern
If I have 2 fields: %album only% and %catalog #%, how to implement pattern for Album field like %album only% [%catalog #%] with convert or action way? Is possible at all?
You want to combine the two separate (custom) tags %album only% and %catalog #% into one single official tag %album% where the catalog # is enclosed by square brackets?
For example:
%album only% contains
Waterloo
%catalog #% contains
123456
You want to see ALBUM as
Waterloo [123456]
You can try Convert Tag -> Tag
Field:
ALBUM
Format string
%album only% '['%catalog #%']'
Please be aware that any existing content in ALBUM will be overwritten.
Oh yes, I missed symbol <'> outside of square brackets, and was confused for that...
Thanks for awaring, that's the reason I always have field %album only% with clear album info.
I will not use it frequently but for especially cases.
